Customized wafer coating service 450-0.15 OD6 Ultra Narrow Bandpass Filter with customized size (certified)
Ultra-narrowband optical interference filter with a 450 nm center wavelength (CWL), a 0.15 nm full-width at half-maximum (FWHM), and wide-range OD6 out-of-band blocking from 390 nm to 1000 nm. This i…
Read More…Ultra-narrowband optical interference filter with a 450 nm center wavelength (CWL), a 0.15 nm full-width at half-maximum (FWHM), and wide-range OD6 out-of-band blocking from 390 nm to 1000 nm. This is a multi-cavity filter with exceptionally steep edges, a flat top, and transmission that is greater than 90% at 515 nm. This ultra-narrowband filter is coated on a 2 mm thick Borofloat® substrate. This ultra-narrow bandpass filters have the highest transmission and narrowest bandwidths currently available. And because they are hard-coated using our innovative SIRRUS plasma deposition process, all of our optical filters are highly durable and resistant to laser damage.
SPECIFICATIONS
Angle of Incidence
0 Degrees
Filter Design
Multi-Cavity
FWHM
< 0.25 nm
Center Wavelength
532 nm Nominal
† Transmission Band(s)
532 nm > 90% T Absolute
Blocking Level
OD6
Dimensions
5.0 mm x 5.0 mm
Substrate Type
Borofloat®
Filter Thickness
2.0 mm
Assembly Type
Anodized Aluminum Ring
Assembly Thickness
3.5 mm
Enter your email address if you'd like to be notified when Customized wafer coating service can be shipped to you:
Flea Market Item:
$48.00
$81.00
