ELECTROLESS PLATING SERVICE-Our flexible process is able to deposit nickel thicknesses between 2µm and 25µm, depending on the requirements and application. Palladium can be deposited in the range of …
Read More…ELECTROLESS PLATING SERVICE-Our flexible process is able to deposit nickel thicknesses between 2µm and 25µm, depending on the requirements and application. Palladium can be deposited in the range of 100nm and 300nm, gold (AURUM) is typically deposited between 30nm and 100nm.
Prajnesh | Aug. 4, 2021
