This adapter converts the Toshiba Tecra 500/510 series's proprietary HDD connector, to a standard 2.5" IDE 44-pin HDD connector.
Designed by Xinming's store in United States of America
This adapter converts the Toshiba Tecra 500/510 series laptop's proprietary HDD connector, to a standard 2.5" IDE 44-pin HDD connector. You can use normal 2.5" IDE HDD up to 17mm thickness in the Tos…
Read More…This adapter converts the Toshiba Tecra 500/510 series laptop's proprietary HDD connector, to a standard 2.5" IDE 44-pin HDD connector. You can use normal 2.5" IDE HDD up to 17mm thickness in the Toshiba Tecra 500/510 series laptops. (but keep in mind that the laptop BIOS does not support HDD or partition larger than a certain size, I think it is 32GB or something? Just a disclaimer)
What's included:
What's NOT included: - The hard drive, obviously.
I used two types of the proprietary connector components, one does not need modification and the other has a little plastic dremeled off to fit. They all function equally well. I will ship them randomly. See the github link for detailed explanation.
Enter your email address if you'd like to be notified when Toshiba Tecra 500/510 series HDD adapter can be shipped to you:
$12.99
