compatible with arduino use STM32F0 MCU
Designed by chimer in ChinaThis seller is taking a break. Sign up below to get an email when they're back!
What is it? eDuino UNO is a High-performance,low-cost ,designer-friendly open Hardware by BestU, fully compatible with the hardware interface、API and IDE of arduino UNO. It is easy to use eDuino if y…
Read More…eDuino UNO is a High-performance,low-cost ,designer-friendly open Hardware by BestU, fully compatible with the hardware interface、API and IDE of arduino UNO. It is easy to use eDuino if you have tried arduino, you can port the running program on Arduino to eDuino UNO rapidly. eDuino Uno would be your best choice of hardware platform if you would like higher performance and better operation effect.
We think that STM32 MCU is very popular and useful. Why we not use it to make a open hardware board. So, we do it.In software, we support a SDK on the arduino IDE. In hardware, all interfaces are compatible with arduino.
1)Easy-to-Use:Power-on(USB Connection or External Power),then work smoothly. 2)Simple Operation:Only click "upload"on the arduino IDE to update eDuino program, self-reset running program 3)Software Compatibility:the code for arduino UNO can be operated on eDuino UNO directly without modification. 4)Hardware Compatibility:most of the accessories for arduino can be used on the eDuino UNO.
Enter your email address if you'd like to be notified when STM32 arduino eDuino UNO can be shipped to you:
