This seller is taking a break. Sign up below to get an email when they're back!
What is it? eNet-ZBP113 module is a 2.4-GHz、IEEE 802.15.4/ZigBee embedded wireless module built in TI CC2530,designed by BestU. Why did you make it? eNet-ZBP113 module can help you to realize the IoT…
Read More…eNet-ZBP113 module is a 2.4-GHz、IEEE 802.15.4/ZigBee embedded wireless module built in TI CC2530,designed by BestU.
eNet-ZBP113 module can help you to realize the IoT application so easy. Self-network、LAPU are the main features of eNet-ZBP113module,It is not necessary for you to understand complex ZigBee Protocol.all the processing part of ZigBee Protocol can be done internally under eNet-ZBP113 module, What you only need to do is to transport data by serial port,which can shorten product lead time tremendously.Meanwhile eNet-ZBP113 module has the advantage of low-power and low-cost.
eNet-ZBP113 module is designed for mass production.So,the quality is assured. eNet-ZBP113 is the best choice of remote monitoring application,such as Smart home controlling、Smart Grid Data Collection、Industrial Automation Control and Security Monitoring and etc.
We provide two kits to evaluate our ZigBee Module, detail documents and confige Tool. They will guide you to use our ZigBee Module more easy.
ZigBee Module quick start guide
ZigBee Module user manual
Enter your email address if you'd like to be notified when ZigBee Module can be use on Raspberry Pi can be shipped to you:
1-4 | $21.95 |
5-49 | $15.90 |
50+ | $12.95 |
$46.21 $49.69
