USB/UART converter based on Silabs CP2104 that makes it easy to upload the ESP32/8266
Designed by chris_maker_shop in Italy
ESP-Uploader Documentazione in Italiano USB/UART converter based on Silabs CP2104 that makes it easy to upload the ESP32/8266 ESP Uploader allow you to program ESP8266, ESP32, ESP01, ESP12 modules bu…
Read More…Documentazione in Italiano
ESP Uploader allow you to program ESP8266, ESP32, ESP01, ESP12 modules but it can also be used in other projects that require a USB/UART converter it is also bread board friendly.
Also on board is a 1A LDO voltage regulator (LDI1117-3.3H) and a led to signal the presence of power. Thanks to the autoreset circuit, you just need to load your code from Arduino IDE or PlatformIO and the module will be reset and started in flash mode automatically. The board is equipped with a USB-C connector and works only at 3.3V
Which board to choose for loading code?
ESP32
Arduino IDE:
Adafruit ESP32 Feather
PlatformIO:
[env:featheresp32]
platform = espressif32
board = featheresp32
framework = arduino
ESP8266
Arduino IDE
Adafruit Feather HUZZAH ESP8266
PlatformIO:
[env:huzzah]
platform = espressif8266
board = huzzah
framework = arduino
Enter your email address if you'd like to be notified when ESP Uploader can be shipped to you:
