Bus Blaster v4 is an experimental, high-speed JTAG debugger from Dangerous Prototypes. PCB ONLY.
Sold By Circuit Circus
Here you can find some of my handworks, inventions, hacks, or discoveries.
But you can also find a wide variety of Open Source PCBs, accessories, and kits.
What is it? Bus Blaster v4 is an experimental, high-speed JTAG debugger from Dangerous Prototypes. Thanks to a reprogrammable buffer, a simple update over USB makes Bus Blaster compatible with many d…
Read More…Bus Blaster v4 is an experimental, high-speed JTAG debugger from Dangerous Prototypes. Thanks to a reprogrammable buffer, a simple update over USB makes Bus Blaster compatible with many different JTAG debugger types in the most popular open source software.
Based on FT2232H with high-speed USB 2.0 Buffered interface works with 3.3volt to 1.8volt targets Reprogrammable buffer is compatible with multiple debugger types Compatible with 'jtagkey', 'KT-link' programmer settings in OpenOCD,urJTAG, and more ships with JTAGkey compatible buffer image pre-programmed Should support Serial Wire Debug when available Mini-CPLD development board: self programmable, extra CPLD pins to header
Partlist Here:
http://dangerousprototypes.com/docs/Minouche_:_Bus_Blaster_v4
Assebmly Video Here:
https://www.youtube.com/watch?v=HD57bsDGwoU
V4 uses a larger CPLD than previous versions. It can now support the SWV feature of Cortex microcontroller for advance debugging when software support is available
SWV is little used and not currently supported in software, most users will be better off with Bus Blaster v3
Fitted in a DP9056 (90x56 mm) standard PCB
Added series resistors to input and output pins to protect against damage and noise
Enter your email address if you'd like to be notified when Bus Blaster can be shipped to you:
