Whether you need an interface to an external chip, a logic analyzer, a debugger, or just a whole lot of pins to bit-bang. PCB ONLY.
Sold By Circuit Circus
Here you can find some of my handworks, inventions, hacks, or discoveries.
But you can also find a wide variety of Open Source PCBs, accessories, and kits.
What is it? GreatFET One is a hardware hacker’s best friend, created by GREAT SCOTT GADGETS. https://greatscottgadgets.com/ With an extensible, open source design, two USB ports, and 100 expansion pi…
Read More…GreatFET One is a hardware hacker’s best friend, created by GREAT SCOTT GADGETS. https://greatscottgadgets.com/
With an extensible, open source design, two USB ports, and 100 expansion pins, GreatFET One is your essential gadget for hacking, making, and reverse engineering. By adding expansion boards called neighbors, you can turn GreatFET One into a USB peripheral that does almost anything.
GreatFET One
Whether you need an interface to an external chip, a logic analyzer, a debugger, or just a whole lot of pins to bit-bang, the versatile GreatFET One is the tool for you. Hi-Speed USB and a Python API allow GreatFET One to become your custom USB interface to the physical world.
programmable digital I/O
serial protocols including SPI, I2C, UART, and JTAG
logic analysis
analog I/O (ADC/DAC)
data acquisition
debugging
versatile USB functions including Facedancer
high-throughput hardware-assisted streaming serial engine
four fabulous LEDs!
GreatFET One is also known by the code name Azalea. For documentation and open source software, visit the GreatFET manual on Read the Docs:https://greatfet.readthedocs.io/en/latest/
For open source hardware design files, see the hardware git repository:https://github.com/greatfet-hardware/azalea
Official Page on GREAT SCOTT GADGETS WEBSITE: https://greatscottgadgets.com/greatfet/one/
GreatFET is a next generation GoodFET intended to serve as your custom Hi-Speed USB peripheral through the addition of expansion boards called “neighbors”.
GreatFET is designed to provide a significant step up in capabilities from GoodFET while making the design manufacturable at a lower cost than GoodFET. In addition to being designed for automated assembly, it can be hand-assembled with a soldering iron, though it is a more complicated assembly than GoodFET. An important similarity to GoodFET is that GreatFET has a USB bootloader in ROM, so it is possible to build a board by hand and install firmware onto it without the need of any external programming hardware.
Enter your email address if you'd like to be notified when GreatFET One (a.k.a. Azalea) PCB can be shipped to you:
Keith | Nov. 6, 2023
