HackRF One is a Software Defined Radio peripheral capable of transmission of radio signals from 1 MHz to 6 GHz. PCB ONLY
Sold By Circuit Circus
Here you can find some of my handworks, inventions, hacks, or discoveries.
But you can also find a wide variety of Open Source PCBs, accessories, and kits.
What is it? HackRF One from Great Scott Gadgets (https://greatscottgadgets.com)is a Software Defined Radio peripheral capable of transmission or reception of radio signals from 1 MHz to 6 GHz. Design…
Read More…HackRF One from Great Scott Gadgets (https://greatscottgadgets.com)is a Software Defined Radio peripheral capable of transmission or reception of radio signals from 1 MHz to 6 GHz. Designed to enable test and development of modern and next generation radio technologies, HackRF One is an open source hardware platform that can be used as a USB peripheral or programmed for stand-alone operation.
1 MHz to 6 GHz operating frequency
half-duplex transceiver
up to 20 million samples per second
8-bit quadrature samples (8-bit I and 8-bit Q)
compatible with GNU Radio, SDR#, and more
software-configurable RX and TX gain and baseband filter
software-controlled antenna port power (50 mA at 3.3 V)
SMA female antenna connector
SMA female clock input and output for synchronization
convenient buttons for programming
internal pin headers for expansion
Hi-Speed USB 2.0
USB-powered
HackRF One has an injection molded plastic enclosure and ships with a micro USB cable. An antenna is not included. ANT500 is recommended as a starter antenna for HackRF One.
HackRF One is test equipment for RF systems. It has not been tested for compliance with regulations governing transmission of radio signals. You are responsible for using your HackRF One legally.
Documentation: https://hackrf.readthedocs.io/en/latest/index.html
Github (Source, Firmware, etc.): https://github.com/greatscottgadgets/hackrf
Enter your email address if you'd like to be notified when HackRF One PCB can be shipped to you:
$28.90
$18.90
$39.90
