Mini Wardriving board based on the wardriver.uk by Joseph Hewitt
Designed by Segfault's Workbench in United States of America
Note, first batch of boards will be delivered in person at DefCon 31. If you are not attending, please do not order. This is a mini wardriving board based on the wardriver.uk by Joseph Hewitt. It rem…
Read More…Note, first batch of boards will be delivered in person at DefCon 31. If you are not attending, please do not order.
This is a mini wardriving board based on the wardriver.uk by Joseph Hewitt. It removes the development boards and modules and replaces them with surface mount parts and is powered via a USB-C port. Reprogramming the ESP modules does require an external serial adapter, but you should be able to do OTA updates over WiFi without.
All you need to get started is a FAT32-formatted MicroSD card and optionally a CR1220 battery to keep memory in the GPS module for faster location fix. Plug in the USB power, then connect to the WiFi network displayed on the screen to connect it to your existing WiFi for management of data files and updates.
Enter your email address if you'd like to be notified when Mini ESP32 Wardriver can be shipped to you:
