Audio & Sync Mixer in Pocket Operator style
Designed by Creative Electronics in NetherlandsNo shipping info available.
If you are a Pocket Operator fan, you probably got frustrated over how to mix the audio signals. Linking each device for sync and audio signals, you are left without the option to easily adjust the v…
Read More…If you are a Pocket Operator fan, you probably got frustrated over how to mix the audio signals. Linking each device for sync and audio signals, you are left without the option to easily adjust the volume for each device/PO.
That is when the idea came to mind to create a 5 channel summing mixer.
5 Channel Summing mixer to mix the audio signals of up to 5 Pocket Operators from Teenage Engineering. The Sync signal is distributed via the mixer, amongst connected PO's. Audio signal is mixable to TRS output as Dual Mono or Mono+Sync.
Be careful to not reverse connect the battery. This might irreversibly damage the mixer. Due to shipping restrictions battery is not included.
Enter your email address if you'd like to be notified when 5 Channel Summing Mixer for Pocket Operators can be shipped to you:
Documentation: (4.33)
Linus | May 26, 2021
Andy | May 13, 2021
Dmytro | April 30, 2021
$110.94
$87.99
$28.00
$137.99
