FM Towns Car Marty Breakout card
Designed by ApexElectronics in United States of America
This is a card that plugs into an FM Towns Car Marty. Generally, the AV cable is impossible to find for Car Marty. It gives you access to S-Video, Composite video, Left and right audio, and mono audi…
Read More…This is a card that plugs into an FM Towns Car Marty.
Generally, the AV cable is impossible to find for Car Marty. It gives you access to S-Video, Composite video, Left and right audio, and mono audio. Any RCA phono connectors work for the RCA terminals. You may know them as the yellow, red and white cables.
To use this, connect your cables to the card first.
Remove the single screw above the 22-pin AV port of the car Marty near the Keyboard port. Then slide this card into the 22P AV port.
Add the screw back into the screw hole securing the card. You might have to use a different-length screw.
There is a photo you can see of a friend using it on his Car Marty for example.
A screw will be provided. However please understand you might need a different screw length.
Also please note that the opposite side (not pictured) will be covered in tape. This is to prevent the Car Marty case from being scratched.
This product has free tracked shipping to any destination.
Enter your email address if you'd like to be notified when FM Towns Car Marty Breakout Card can be shipped to you:
