MIDI Test Keyboard Controller (Build you own DIY PCB Kit)
Designed by Data Point Ltd in United KingdomNo shipping info available.
DIY MIDI Keyboard Controller (PCB Kit) Fun little project kit to build your own little MIDI Keyboard. Basic PCB soldering skills required. Specifications: MIDI Out - Connect to your MIDI synth, keyb…
Read More…Fun little project kit to build your own little MIDI Keyboard. Basic PCB soldering skills required.
Specifications:
Pressing two buttons at one (i.e C & D keys) will play the sharp notes (i.e C#).
Measurements:
The ATMEGA328 is supplied with Arduino bootloader and pre-programmed with the sketch code used to control the board.
The code is also available on GitHub at: github.com/jamesleesaunders/arduino_midi
Includes:
This is a DIY project - buyer takes responsibility for soldering. No returns if soldering has been started or damage to the PCB.
Enter your email address if you'd like to be notified when Build you own MIDI Keyboard Controller can be shipped to you:
$199.00
$300.00
$645.00
