SIM7600G-H 4G modem board, in Raspberry Pi size, global usable。
Designed by david in China
This is the document for SIM7600G-H 4G-modem board. Introduction Features of this board: Same dimension as Raspberry Pi, easily stacked up with Raspberry Pi. Support all functions provided by SIM…
Read More…This is the document for SIM7600G-H 4G-modem board.
Support all functions provided by SIM7600G-H.
Powered by micro-USB cable or external 5.0V DC supply.
Push-push Nano-SIM socket.
Flip-open micro-SD socket.
3.5mm earphone socket and 2-pin speaker connector.
On-board micphone.
40-pin connector at same place with Raspberry Pi(Not mounted).
20-pin connector that exports major signals of SIM7600G-H.
SMA connectors for main/aux and GPS antenna.
Buttons for Reset and Power function.
2-pin connectors for boot mode, flight mode, and power up selection.
2 LEDs for power and net status indication.
Features of SIM7600G-H:
LTE Cat4 module, supports LTE-TDD/LTE-FDD/HSPA+/GSM/GPRS/EDGE etc.
Multi-constellation GNSS receiver.
Frequency bands:
LTE-TDD B34/B38/B39/B40/B41.
LTE-FDD B1/B2/B3/B4/B5/B7/B8/B12/B13/B18/B19/B20/B25/B26/B28/B66.
UMTS/HSPA+ B1/B2/B4/B5/B6/B8/B19.
GSM/GPRS/EDGE 850/900/1800/1900MHz.
LTE Cat4: uplink up to 50Mbps, downlink up to 150Mbps.
HSPA+: uplink upto 5.76Mbps, downlink up to 42Mbps.
UMTS: uplink/downlink upto 384Kbps.
EDGE: uplink/downlink upto 236.8Kbps.
GPRS: uplink/downlink upto 85.6Kbps.
Control via AT commands.
USB drivers for Windows 7/8/10, Linux.
TCP/IP/IPv4/IPv6/Multi-PDP/FTP/FTPS/HTTP/HTTPS/DNS.
RNDIS/NDIS/ECM.
DTMF/Audio Playing.
USB audio and VoLTE.
Interface: USB 2.0, UART, USIM, PCM, MMC/SD, ADC, I2C. Antenna.
Certifications on going: CE/RCM/FCC/IC, PTCRB/GCF, AT&T/Verizon, RoHS/REACH.
The following figure show the resources on the board.
Number | Reference | Description |
1 | J12 | MicroUSB connector. |
2 | LED2 | Power LED. |
3 | J5 | Connect this jumper to enable flight mode. |
4 | J4 | Connect this jumper to enable power. |
5 | J8 | NanoSIM card socket. |
6 | J10 | Speaker connector. |
7 | J11 | 3.5mm earphone connector. |
8 | M1 | Micphone. |
9 | LED1 | Net status LED. |
10 | J14 | 40-pin raspberry Pi connector, NO connection with other part on this board, just for stacking. |
11 | J7 | MicroSD card socket. |
12 | U1 | SIM7600 module. |
13 | J1 | Main antenna. |
14 | J2 | Aux. antenna. |
15 | J9 | 20-pin connector, refer to the next section for its pin assignment. |
16 | J3 | GPS antenna. |
17 | AN1 | Power button if J4 is not connect. |
18 | AN2 | Reset button. |
19 | J13 | 5V DC power supply connector. |
20 | J15 | Connect this jumper to supply power from MicroUSB; DO NOT connect it while using J13 to supply power. |
Most of important signals are exported by 20-pin connector J9, the following table shows its assignment.
Number | SIM7600G-H Pin | Description |
1 | 3.3V | |
2 | 5.0V | |
3 | 4 | RESET |
4 | 3 | PWRKEY |
5 | 75 | PCM_SYNC |
6 | 76 | PCM_CLK |
7 | 73 | PCM_OUT |
8 | 74 | PCM_IN |
9 | 69 | UART1_RI |
10 | 71 | UART1_TXD |
11 | Not connect | |
12 | 68 | UART1_RXD |
13 | 55 | I2C_SCL |
14 | 56 | I2C_SDA |
15 | 49 | STATUS |
16 | 54 | FLIGHTMODE |
17 | 46 | ADC2 |
18 | 47 | ADC1 |
19 | GND | |
20 | GND |
Delivery includes:
1 main board.
2 LTE antenna.
1 GNSS antenna.
1 MicroUSB cable.
4 jumpers.
Enter your email address if you'd like to be notified when SIM7600G-H 4G modem board can be shipped to you:
$39.49
$49.90
