Changes the signal voltage level from +5V -> +3.3V and +3.3V -> +5V to permit communication between various development boards
Designed by DNR Enterprise in United States of AmericaThis seller is taking a break. Sign up below to get an email when they're back!
What is it? This is a module for use on a DNRE PowerBrick power supply Expansion Module header or directly on a breadboard using user supplied +5V and +3.3V. Why did you make it? To facilitate commun…
Read More…This is a module for use on a DNRE PowerBrick power supply Expansion Module header or directly on a breadboard using user supplied +5V and +3.3V.
To facilitate communication between Arduino boards and Raspberry Pi on GPIO pins or I2C +5V sensors.
User assembled kit with four (4) 2N7000 N-FET transistors, and male pins for signal connections for a more reliable signal transfer. Included in the kit are eight (8) M->F 20cm high quality jumper wires. These wires use a crimp connector and Dupont housing for superior reliability and positive contacts.
Enter your email address if you'd like to be notified when PowerBrick Expansion Module: 2N7000 Level Shifter can be shipped to you:
Burr Ridge, IL, United States of America
$3.95
