Dual voltage; +5V0 & +3V0 power supply with multiple output connection options and an Expansion Module header to increase functionality.
Designed by DNR Enterprise in United States of AmericaThis seller is taking a break. Sign up below to get an email when they're back!
What is it? The DNR Enterprise Power Supply is a two regulator power supply configured to output +5V0 and +3V3 DC using 5 Amp Max/80% 4 Amp continuous supply. An Expansion module header permits addi…
Read More…The DNR Enterprise Power Supply is a two regulator power supply configured to output +5V0 and +3V3 DC using 5 Amp Max/80% 4 Amp continuous supply. An Expansion module header permits adding additional functionality and/or power connection capability. Native power connections include configurable underside DC power and ground (0V) pins for direct breadboard connections, one terminal block per regulator for PCB to wire connections and an Expansion Module header. Input power connections via 2.1x5.5mm barrel or terminal block from a 12VDC power adapter.
I found using multiple low power breadboard power adapters to be disappointing and a wiring mess when multiple were necessary to power my experiments.
High power output dual voltage regulators with the ability to add increased functionality with various expansion modules including socket headers for jumper wires, signal level shifter, and power connectors; 2.1x5.5 barrel and USB-A. Short circuit protection on the input power and regulator output connections. LED indicators provide quick indication of proper connections when illuminated and a short circuit when off during operation. Extra long mounting screws provide connection to ground and easy common ground connections when necessary using alligator clamp leads. The PCB is manufactured using 2oz Copper clad material to accommodate the high current regulator outputs.
Documentation link contains detailed assembly instructions.
Enter your email address if you'd like to be notified when PowerBrick Mini - Two Regulator Power Supply can be shipped to you:
Burr Ridge, IL, United States of America
$8.90
$34.95
$87.99
$95.00
