868MHz 915MHz 1W 30dbm high power TCXO sx1262 module DRF1262TL
Designed by DORJI in China
Features: (G)FSK/4(G)FSK/LoRa Modulation 868/915Mhz transceiver Max.30dBm output power -147dBm sensitivity Standard SPI interface Low RX current: 6.0 mA Automatic RF sense and CAD monitor Data Rate:…
Read More…DRF1262TL module consists of RFIC SX1262, thin SMD crystal, PA and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don’t need to spend time in RF circuit design and choose suitable antennas for different applications. DRF1262TL operates at 4.0~5.5V with extra low standby current which makes it suitable for battery powered-up applications.
DRF1262TL adopts ±1ppm high accuracy TCXO which makes it possible to use narrower bandwidth to achieve the high sensitivity up to -147dBm.
Remote Control * Remote AMR * Home Automation * Personal data logger * Wireless sensor network * Remote Keyless entry * Wireless PC peripherals
Enter your email address if you'd like to be notified when 30dBm 1W 868MH 915MHz sx1262 Module DRF1262TL can be shipped to you:
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
