Long range low power 433MHz sx1268 sx1262 TTL UART interface module DRF1268DS
Designed by DORJI in China
Featiures: 433MHz ISM frequency band High sensitivity: -143dBm @ power mode 0 Max. Output power: 22dBm RF data rate: 0.073~62.5k bps UART data rate: 1.2~57.6k bps Standard /star network mode Multipl…
Read More…Home automation, Security alarm, Telemetry, Automatic meter reading, Contactless access, Wireless data logger, Remote motor control, Wireless sensor network
DRF1268DS is a type of low cost and long range data radio modem based on the new generation of Lora chip sx126x from Semtech. It has the advantages of low receive current, long transmission range and strong anti-interference ability. It adopts high resolution TCXO which improves the reliability and robustness in the whole working temperature. DRF1268DS can work steadily even at extra low RF data rate. It has the standard UART interface so users can change the default parameters by using the configuration tool through computer or AT commands by MCU.
The module has two work modes: standard data transmission (or transparent data transmission) and star network. It also provides four types of power saving modes: short-preamble, long-preamble, CAD monitor and full sleep, which can be switched by the levels of I/O pins. The maximum data package size of the module is 200 bytes.
Enter your email address if you'd like to be notified when 433MHz 22dBm Lora sx1268 UART TTL Module can be shipped to you:
1-2 | $7.98 |
3-9 | $7.78 |
10+ | $7.68 |
$9.98
$3.68
$8.98
$8.28
$4.28
$26.00
$1.20
$8.68
$540.00
$23.50
