Si4463 module without MCU on board RF front-end module
Designed by DORJI in China
Overview (G)FSK/4(G)FSK transceiver module Features: 433MHz transceiver 20dBm output power -126dBm sensitivity Standard SPI interface Digital RSSI output Programmable carrier sense indicator Data Ra…
Read More…DRF4463F is a type of low cost RF front-end transceiver module based on SI4463 from Silicon labs. It keeps all the advantages of RFIC SI4463 but simplifies the circuit design. The high sensitivity (-126dBm) and 20dBm high power output make the module suitable for most short range applications.
DRF4463F module consists of RFIC Si4463, thin SMD crystal and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don't need to spend time in RF circuit design and choose suitable antennas for different applications. DRF4463F operates at 1.8~3.6V with extra low standby current which makes it suitable for battery powered-up applications.
The price is only for 1pcs of 433MHz module DRF4463F-043S
Enter your email address if you'd like to be notified when 433MHz wireless RF si4463 transceiver module can be shipped to you:
1-4 | $4.68 |
5-9 | $3.80 |
10+ | $3.60 |
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
