Long range low power 868MHz 915MHz sx1262 TTL UART interface module DRF1262DS
Designed by DORJI in China
Featiures: 868/915MHz ISM frequency band High sensitivity: -143dBm @ power mode 0 Max. Output power: 22dBm RF data rate: 0.073~62.5k bps UART data rate: 1.2~57.6k bps Standard /star network mode Mul…
Read More…Home automation, Security alarm, Telemetry, Automatic meter reading, Contactless access, Wireless data logger, Remote motor control, Wireless sensor network
DRF1262DS is a type of low cost and long range data radio modem based on the new generation of Lora chip sx126x from Semtech. It has the advantages of low receive current, long transmission range and strong anti-interference ability. It adopts high resolution TCXO which improves the reliability and robustness in the whole working temperature. DRF1262DS can work steadily even at extra low RF data rate. It has the standard UART interface so users can change the default parameters by using the configuration tool through computer or AT commands by MCU.
The module has two work modes: standard data transmission (or transparent data transmission) and star network. It also provides four types of power saving modes: short-preamble, long-preamble, CAD monitor and full sleep, which can be switched by the levels of I/O pins. The maximum data package size of the module is 200 bytes.
Enter your email address if you'd like to be notified when 868MHz 915MHz 22dBm sx1262 UART TTL module can be shipped to you:
1-2 | $8.68 |
3-9 | $8.48 |
10+ | $8.38 |
Documentation: (3.00)
Shipping: (4.00)
Communication: (3.00)
Duane | March 4, 2020
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
$16.80 $21.00
$7.98
$432.00 $540.00
$7.50
