Semtech LoRa SX1262 433 868Mhz 915Mhz RF wireless Module DRF1262G
Designed by DORJI in China
Features: (G)FSK/4(G)FSK/LoRa Modulation 433/868/915MHz transceiver 22dBm output power -137dBm sensitivity Standard SPI interface Low RX current of 4.6 mA Automatic RF sense and CAD monitor Data Rat…
Read More…DRF1262G module consists of RFIC SX1262, thin SMD crystal and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don’t need to spend time in RF circuit design and choose suitable antennas for different applications. DRF1262G operates at 1.8~3.6V with extra low standby current which makes it suitable for battery powered-up applications.
Because DRF1262G is purely hardware module and it adopts ±10ppm crystal which the resolution of it places a important role in calculating spreading factor, bandwidth, etc. Users need to read the datasheet of SX1262 carefully in order to use the module in the best performance.
Enter your email address if you'd like to be notified when 868MHz 915MHz SX1262 Module DRF1262G can be shipped to you:
1-5 | $4.68 |
6-9 | $4.90 |
10-19 | $4.80 |
20+ | $4.70 |
Dimitar | July 2, 2021
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
