Semtech Lora 868Mhz 915Mhz SX1276 RF wireless module DRF1276G
Designed by DORJI in China
What is it? Frequency Range: 868/915MHz Modulation: FSK/GFSK/MSK/LoRa SPI Data Interface Sensitivity: -139dBm Output Power: +20dBm Data Rate: <300 kbps 127dB dynamic Range RSSI Excellent bloc…
Read More…DRF1276G is a type of low cost RF front-end transceiver module based on SX1276 from Semtech Corporation. It keeps the advantages of RFIC SX1276 but simplifies the circuit design. The high sensitivity (-139dBm) in LoRa modulation and 20dBm high power output make the module suitable for long range and low data rate applications.
DRF1276G module consists of RFIC SX1276, thin SMD crystal and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don’t need to spend time in RF circuit design and choose suitable antennas for different applications. DRF1276G operates at 1.8~3.6V with extra low standby current which makes it suitable for battery powered-up applications
Enter your email address if you'd like to be notified when 868Mhz 915Mhz SX1276 module DRF1276G can be shipped to you:
1-9 | $4.68 |
10-19 | $4.40 |
20+ | $4.20 |
Armtronix | Feb. 11, 2018
Mato | April 5, 2017
$7.89 $9.28
$8.48 $9.98
$3.13 $3.68
$7.63 $8.98
$7.04 $8.28
$11.90 $14.00
$3.64 $4.28
$6.78 $7.98
$3.64 $4.28
$4.15 $4.88
$7.89 $9.28
$3.98 $4.68
