Semtech Lora 868MHz SX1272 module compatible for SX1276 DRF1272F
Designed by DORJI in China
Features: Frequency Range: 868MHz Modulation: FSK/GFSK/MSK/LoRa SPI Data Interface Sensitivity: -137dBm Output Power: +20dBm Data Rate: <300 kbps 127dB dynamic Range RSSI Excellent blocking immu…
Read More…Features:
DRF1272F is a type of low cost RF front-end transceiver module based on SX1272 from Semtech Corporation. It keeps the advantages of RFIC SX1272 but simplifies the circuit design. The high sensitivity (-137dBm) in LoRa modulation and 20dBm high power output make the module suitable for low range and low data rate applications.
DRF1272F module consists of RFIC SX1272, thin SMD crystal and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don’t need to spend time in RF circuit design and choose suitable antennas for different applications. DRF1272F operates at 1.8~3.6V with extra low standby current which makes it suitable for battery powered-up applications. Because DRF1272F is purely hardware module and it adopts ±10ppm crystal which the resolution of it places a important role in calculating spreading factor, bandwidth, etc. Users need to read the datasheet of SX1272 carefully in order to use the module in the best performance.
Enter your email address if you'd like to be notified when 868MHz Lora SX1272 Module DRF1272F can be shipped to you:
1-5 | $3.98 |
6-9 | $4.30 |
10-19 | $4.20 |
20+ | $4.10 |
Product: (3.00)
Documentation: (4.00)
Shipping: (4.00)
Communication: (4.00)
Anucha | March 20, 2016
Sjoerd | Feb. 4, 2016
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
