Extra low power data radio modem sx1212 module---DRF1212D10-043S1
Designed by DORJI in China
Overview 433MHz transceiver 10dBm output power -113dBm sensitivity Receive current: <3mA Multi-channel selection Four working modes Standard UART interface Supply voltage: 2.1~3.6V Details DRF1212…
Read More…Overview
Details
DRF1212D10 is a low-cost sub-1 GHz transceiver module designed for operations in the unlicensed ISM (Industrial Scientific Medical) and LPRD bands. FSK (Frequency Shift Keying) modulation/demodulation, multi-channel operation, high bandwidth efficiency and anti-blocking performance make DRF1212D10 modules easy to realize the robust and reliable wireless link.
The module can be configured to work in different channels with 200 KHz space. It adopts high efficient looped interleaving EDAC (Error Detection and correction) coding with coding gain up to 3dB which keeps in advance in error correction and coding efficiency over normal FEC (Forward Error Correction) coding. Because of its high reliability in correction, modules can filter error and fake information automatically and realize truly transparent wireless link, which makes DRF1212D10 very suitable in the rigid communication environment.
DRF1212D10 integrates two 256 bytes buffer. When the buffer is empty, users can transfer nearly 217 bytes data per time and even limitless data transfer can be achieved as long as RF data rate (RF module to RF module) is configured to be faster than UART data rate (MCU to RF module). DRF1212D10 provides standard UART/TTL interface. Users can choose seven data rates and three parity checks which make DRF1212D10 possibly tailor-made for different applications. DRF1212D10 operates at 2.1~3.6V with extra low power consumption. The current in sleep mode can be minimized to 1.5uA and the current in receive mode no more than 3mA makes modules very suitable for battery powered-up applications.
Ordering details
According to package, DRF1212D10 can be divided into DIP package (DRF1212D10-043A) and SMD package (DRF1212D10-043S1). The package type here refers to SMD package which is the same as the picture. This module doesn't contain ID. Please check the datasheet of DRF1212D10 module.
Enter your email address if you'd like to be notified when Extra low power sx1212 module-DRF1212D10 can be shipped to you:
Documentation: (4.00)
Josh | Feb. 26, 2016
$9.28
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$9.50
$9.00
$7.50
