433.92MHz low cost ASK transmitter module DRA889TX
Designed by DORJI in ChinaThis product is no longer available for sale.
Frequency Range: 433.92MHz output power:12dBm@3V & 27dBm@12V Tx current: 12mA@3V & 150mA@12V Temperature: -20~+70C Supply voltage: 2.2~12V DRA889TX is a type of low cost ASK transm…
Read More…DRA889TX is a type of low cost ASK transmitter module which is designed with SAW resonator and high power PA for cost-efficient solutions. It can be used in wireless door opener, robot control, security alarm and related applications.
Please note that the output power is not only decided by the working voltage but also the logic level of Data pin. The Max. output power is measured in 12V working voltage and 12V logic high level. Under the same working voltage, lower logic high level means lower output power.
This price includes 4pcs of DRA889TX module
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
$28.00
$175.00
$6.99
