UHF band Ham radio Amateur radio walkie talke module wireless audio DRA818U
Designed by DORJI in China
FEATURES Frequency Range: 400~470MHz Tx/Rx frequency independent Channel space: 12.5/25KHz Configurable multi-channels Sensitivity: -122dBm Output power: +27/30dBm CTCSS / CDCSS codes 8 volume level…
Read More…DRA818U is a type of compact wireless voice transceiver module based on RFIC RDA1846 and works in UHF band. It integrates high speed microcontroller, high performance wireless transceiver IC, high power PA, audio process and squelching circuits. It provides standard UART interface which users can easily configure appropriate parameters for different applications. Users can easily construct a walkie-talkie system by connecting microphone, audio PA and speaker.
Some parameters of DRA818U modules can be changed by following the commands in this section, which provide flexibility for designers to optimize related parameters to achieve the best performance. DRA818U modules use standard UART interface to communicate with microcontrollers or other hosts. The default data format is: 8 data bits, 1 stop bit, no parity and 9600 kbps data rate.
DRA818U and DRA818V are based on RDA1846. Comparing to DRA808M based on RDA1845, CDCSS and audio control AT command are added, which provides more flexibility for the users who need to process audio signal more precisely. DRA818U is the UHF band version of DRA818V. From the field testing results, the RFIC on DRA818U module should automatically filter the frequencies below 300Hz no mater Highpass filter is enabled or not so please pay attention to it if the applications need low frequencies.
This price includes 1pcs of DRA818U module.
Enter your email address if you'd like to be notified when UHF band Ham radio walkie talke module DRA818U can be shipped to you:
| Quantity | Price |
| 1 | $8.98 |
| 2-9 | $9.68 |
| 10+ | $8.98 |
$7.89 $9.28
$8.48 $9.98
$3.13 $3.68
$7.63 $8.98
$7.04 $8.28
$11.90 $14.00
$3.64 $4.28
$6.78 $7.98
$7.63 $8.98
$19.35 $21.50
$9.90 $11.00
$9.00 $10.00
