Sinclair ZX81 breakout board used for prototyping projects (PCB only)
Designed by Jester Ace in United KingdomNo shipping info available.
What is it? This is a breakout board for the Sinclair ZX81. It allows you to quickly prototype projects for the ZX81. Dupont cables can be used to connect the ZX81 breakout baord to your project on b…
Read More…This is a breakout board for the Sinclair ZX81. It allows you to quickly prototype projects for the ZX81. Dupont cables can be used to connect the ZX81 breakout baord to your project on breadboard for example. You can choose how the breakout board is to be connected to the ZX81, soldered or edge connector, and which headers, male or female, are soldered to the PCB giving you full control how you want your breakout board to be. The breakout header footprint is for 2.54mm pitch and these headers are available from every component vendor, including EBay.
The breakout board is also compatible with Timex 1000 and 1500 computers.
Soldering wires directly to a ZX81 edge connector, as a breakout method, is brittle and requires re-soldering every-now-and-again; slowing down your project prototyping. This breakout board allows a more robust method of breaking out for your project prototypes.
Breakout boards have not been available for the ZX81 for many years. These are available now since tidy prototypes can give you a better proof of concept prototype, and a project needs a robust way of interfacing with the ZX81.
Please note these items are shipped from the United Kingdom. For receiving in countries outside of the U.K. you will be liable for any import Customs Duty and VAT charges where imposed, and any handling fees imposed by the courier.
Enter your email address if you'd like to be notified when ZX81 Breakout Board (PCB only) can be shipped to you:
