The Arduino Serial Graph Tool allows up to eight channels to be easily plotted on a PC. Each channel can have up to 16 bit data at 4 MHz.
Designed by Earth People Technology in United States of AmericaThis product is no longer available for sale.
$56.99
$13.99
$6.99
The Serial Graph Tool for the Arduino Uno provides a simple interface for graphing data to the PC from the Uno. It can graph up to 8 separate channels. Each channel can be eight, ten, twelve, or sixt…
Read More…The Serial Graph Tool for the Arduino Uno provides a simple interface for graphing data to the PC from the Uno. It can graph up to 8 separate channels. Each channel can be eight, ten, twelve, or sixteen bits. It has several tools that allow the data to be scaled for examination. Scaling can be performed in the Vertical and Horizontal. Each channel can be turned on or off for display. The Serial Graph Tool has easy to use Arduino functions to transmit data to be graphed from the Uno. It uses the SPI bus so data is transferred at 4 Megabits per second.
The Arduino boards are increasing used in areas where they can convert sensor information into real data. The data needs to be realized in a visual format for observation, comparison and storage. The Serial Graph Tool easily allows user to display their data on the PC. The data can be scaled in the vertical or horizontal direction to view fast of slow moving events.
The Serial Graph Tool is easy to use. Just fill a buffer with your data in an Arduino Sketch. Then select a channel, select number of data bits for the data. Call a single function to write the entire buffer to the Serial Graph Tool. Call a single function to cause the tool to display the data.
FEATURES - Shield plugs into Arduino Uno - Complete Arduino Library Makes Programming Quick and Easy - Graphs up to Eight Channels Simultaneously in Real Time on a Windows PC - Graph Any Data Up To 16 Bits - Transfers Data from the Arduino over the SPI bus, speeds up to 4 Mbits/sec
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
$24.95
