Multi-Volt Dual Channel USB To Serial Adapater Provides Two Serial UARTs
Designed by Earth People Technology in United States of AmericaThis product is no longer available for sale.
$56.99
$13.99
$6.99
Designed and Assembled in the United States of America FTDI Breakout Board with two Serial Ports Designed to provide serial communications via to independent UARTs. It allows digital communications w…
Designed to provide serial communications via to independent UARTs. It allows digital communications with any target device voltage from +1.2V to +5V.
The Multi-Volt Dual Channel is compatible with Windows, Linux and Apple.
This device connects to an open USB port on a PC and provides two independent serial ports. Each port is independently controlled by application software. The EPT Multi-Volt Dual UART board incorporates the FTDI FT2232H chip.
This board is designed to communicate with any Input/Output from +1.2V to +5V. The way it works is the target device provides the output power and voltage for the EPT Multi-Volt Dual UART board. The target device powers the output buffers which provide the Input/Output from the FTDI FT2232H chip. The target device must provide 15mA at the selected voltage to properly power the buffer chips.
4 Reviews | 317 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
$12.80
$16.99
