The VisiPort is the Worlds smallest USB To Serial Board. It measures 16x19 mm and is designed to mate directly to the Mini and Mini Pro.
Designed and Assembled in the United States of America Includes a Pack of three VisiPort's (FTDI USB To Serial Breakout Board) The VisiPort is a USB To Serial Module that has been designed to program…
It provide a Virtual COM Port (VCP) on any PC including Windows, Linux and Mac. The output is TTL, selectable between +3.3V and +5V. Its small size allows it to fit into bread board applications where other programmers are too big and bulky. This serial to USB adapter provides power to any device: - +3.3V up to 250mA - +5V up to 480mA
Its six pin female header connects easily to a Mini Pro with no bread board needed. It has one green LED that indicates power is applied to the FTDI chip. There are two amber LEDs to indicate when Tx and Rx are active.
Use the three pin jumper in the upper right corner to select I/O voltage of the VisiPort. This selection allows compatibility with all Arduinos.
The Micro USB connector is lower profile and allows cables to connect into the center of the VisiPort. This keeps the overall size smaller than any other programmer.
Enter your email address if you'd like to be notified when FTDI USB To Serial Breakout Board (Pack of 3) can be shipped to you:
Shipping: (4.50)
Parker | Sept. 10, 2015
Jason | March 19, 2015
4 Reviews | 320 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
