The MegaMax makes programmable logic easy. It is a CPLD development platform that includes a CPLD, JTAG programmer, and data transfer path.
The MegaMax is an easy to use CPLD development system The MegaMax DVD provides detailed step by step instructions to quickly guide the user to create a project. The entire Quartus Prime Lite software…
Read More…The MegaMax DVD provides detailed step by step
is included on the DVD. This let's you bypass the
lengthly download process involved in getting
the 3.6 GB file. Once the Quartus software is
on your desktop, we will show you how to create
a project, write you first LED blinky code,
compile and program the CPLD.
The CPLD on the MegaMax can be programmed with the code created by the user. Programming is quick and easy. All that is required is a standard USB cable with a Micro B connector and the Quartus Software installed on the PC. There are no extra parts to buy - just plug in the USB cable and connect the MegaMax to the PC
The MegaMax easily connects to other Hobby Electronics. The durable 74LVC82245 Bus Transceivers allow up to 50mA per Output on the Stackable Headers. This kind of power can drive all kinds of electronics such as long distance cables, LEDs, and high speed electronics.
It also provides a high speed data transfer mechanism between the MegaMax board and a host PC. The MegaMax development system provides a convenient, user-friendly work flow by connecting seamlessly with Altera’s Quartus Prime Lite software. The user will develop the code in the Quartus environment on a Windows Personal Computer. The programmable logic code is loaded into the CPLD using only the Quartus Programmer tool and a standard USB cable. The Active Host SDK provides a highly configurable communications interface between CPLD and host. It connects transparently with the Active Transfer Library in the CPLD code. This Active Host/Active Transfer combination eliminates the complexity of designing a USB communication system. No scheduling USB transfers, USB driver interface or inf file changes are needed. The MegaMax development system is a unique combination of hardware and software.
Use the C# examples included in the DVD to create your own display Window on the PC.The user comes complete with tutorial to instruct the user to easily build a Windows program that can display any data from user code or other electronic device. The C# interface uses similar function calls to the Arduino function calls.
MegaMax kit contains the MegaMax and a DVD which includes the User Manual that walks the user through setting up the drivers, software, and the test application. There is also a full tutorial in writing your first CPLD project and C# application. All the code for the projects are included.
Enter your email address if you'd like to be notified when Intel/Altera 5M570 CPLD Development Kit - MegaMax can be shipped to you:
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$6.99
$24.99
$115.00
$37.99
$260.00
