The UnoMax is an easy to use CPLD development system. It includes a four Channel ADC and a built in programmer
Designed and Assembled in the United States of America The UnoMax CPLD Development Kit The UnoMax makes programmable logic easy with an all inclusive development platform. It includes an Intel/Altera…
The UnoMax makes programmable logic easy with an all inclusive development platform. It includes an Intel/Altera 5M570 CPLD, JTAG programmer, and a four channel ADC with 300KS/second sample rate. You can create your HDL code, program it into the CPLD and interact with the hardware via a Windows PC.
The UnoMax DVD provides detailed step by step instructions to quickly guide the user to create a project. The entire Quartus Prime Lite software is included on the DVD. This let's you bypass the lengthly download process involved in getting the 3.6 GB file. Once the Quartus software is on your desktop, we will show you how to create a project, write you first LED blinky code, compile and program the CPLD.
The CPLD on the UnoMax can be programmed with the code
created by the user. Programming is quick and easy. All that is
required is a standard USB cable with a Mini B connector and
the Quartus Software installed on the PC. There are no extra parts
to buy - just plug in the USB cable and connect the UnoMax to the PC.
The UnoMax has four headers that are positioned to allow connection with the Arduino Uno Shields. You can use the CPLD to perform high speed communications, multi sensor fusing or extra storage capacity.
The UnoMax easily connects to other Hobby Electronics. The durable 74LVC82245 Bus Transceivers allow up to 50mA per Output on the I/O Headers. This kind of power can drive all kinds of electronics such as long distance cables, LEDs, and high speed electronics.
It also provides a high speed data transfer mechanism between the UnoMax board and a host PC. The UnoMax development system provides a convenient, user-friendly work flow by connecting seamlessly with Altera’s Quartus Prime Lite software. The user will develop the code in the Quartus environment on a Windows Personal Computer. The programmable logic code is loaded into the CPLD using only the Quartus Programmer tool and a standard USB cable. The Active Host SDK provides a highly configurable communications interface between CPLD and host. It connects transparently with the Active Transfer Library in the CPLD code. This Active Host/Active Transfer combination eliminates the complexity of designing a USB communication system. No scheduling USB transfers, USB driver interface or inf file changes are needed. The UnoMax development systemis a unique combination of hardware and software.
Use the C# examples included in the DVD to create your own display Window on the PC.The user comes complete with tutorial to instruct the user to easily build a Windows program that can display any data from user code or other electronic device. The C# interface uses similar function calls to the Arduino function calls.
Examine four analog channels running up to 300 KSamples/second. The hardware has been simplified to remove extra cost. The input signals are limited to 0 to +5Volts and the sample rate is shared across all four channels. If you run one channel only, it will take advantage of the 300KSamples/second. If you run four channels, each channel will have a maximum sample rate of 75 KSamples/second.
UnoMax kit contains the UnoMax and a DVD which includes the User Manual that walks the user through setting up the drivers, software, how to use to the test application. There is also a full tutorial in writing your first CPLD project and C# application. All the code for the projects are included.
Enter your email address if you'd like to be notified when Intel/Altera 5M570 CPLD Development Kit - UnoMax can be shipped to you:
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
$115.00
$37.99
$56.99
