SML-LX0404 LED RGB Breakout Board
SML-LX0404 LED RGB Breakout Board The LED RGB Breakout Board provides a simple interface to control four LED RGBs for a total of 12 LEDs from any MCU (including the Arduino family). It is designed to…
Read More…The LED RGB Breakout Board provides a simple interface to control four LED RGBs for
connect directly to the standard bread board with a reduced footprint. Once connected
to an MCU, the MCU can provide a sink for each LED.
The LED RGB Breakout Board consists of four Lumex SML-LX0404SIUP LED chips.
The SML-LX0404 chip is a current sink and can be connected to any MCU.
The anode should be connected to +3.3V. The reason for this is the Series resistors
are calculated for current limiting based on +3.3V. Changing the anode
voltage to another source will change the brightness emitting from each LED. Because
the SML-LX0404 chips are current sink, the user can connect to either +5V or +3.3V
Arduino (or other MCUs) and control each LED.
Parameter | Red LED | Green LED | Blue LED | Units |
Peak Wavelength | 632 | 518 | 564 | nm |
Forward Voltage | 1.75 | 2.75 | 2.60 | Volts |
Leg Current | 5 | 5 | 5 | mA |
Resistor | 310 | 110 | 140 | Ohms |
Axial Intensity | 30 | 40 | 20 | mcd |
The LED RGB Breakout Board comes with example software that blinks individual LEDs from the External MCU (Such as the Arduino Mini Pro). The user can display multiple colors using each LED RGB. The MCU will provide pulse width modulated control for each LED. Changing the duty cycle of each LED changes the overall color of the LED RGB.
Enter your email address if you'd like to be notified when LED RGB Breakout Board can be shipped to you:
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
$24.99
$59.00
$9.98
$8.95
