The Power G is designed to provide a bench top style power supply for Debugging Arduino and sensors
Designed by Earth People Technology in United States of AmericaNo shipping info available.
The PowerG Arduino Dual Power Supply The PowerG gives you the ability to control power like the expensive bench top power supplies. It provides two outputs: 5V-12V and 1V-3.3V. You have a choice of c…
Read More…The PowerG gives you the ability to control power like the expensive
You have a choice of current outputs. Use the PowerG connected directly
to your laptop and provide a total of 300mAs for both supplies. Or use the
optional 5V external power and provide up to 1.2A for each supply individually.
The PowerG has two separate Switching Power Supplies. The Power Supply A is a boost regulator which converts the +5V input into +5.5V to +12V output. The Power Supply B is a buck regulator that converts the +5V input into +1V to +3.3V output.
The PowerG provides two separate power supplies directly from your laptop. You can power your Arduino, power your sensor from a separate power source, and upload a sketch from the Arduino IDE directly to the bootloader all while using the PowerG.
You can also get a graph of the voltage and current from both
power supply outputs.
Each power supply can be turned on or off individually.
A single Micro B USB cable is all that is needed to
connect between the PowerG and the PC
The PowerG also has a built in USB to Serial Adapter. You can connect up your Arduino
and use the IDE to load in a sketch.
Enter your email address if you'd like to be notified when The PowerG Arduino Dual Power Supply can be shipped to you:
Steve | Sept. 4, 2015
4 Reviews | 320 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
