This is a three pack of the venerable TMP102 Temperature Sensor Breakout Board. Each board includes the TMP102 chip
TMP102 Temperature Sensor Breakout Board The TMP102 Temperature Sensor chip from Texas Instruments. It can measure the ambient temperature between -25℃ to +85℃. The temperature is measured with an ac…
Read More…The TMP102 Temperature Sensor chip from Texas Instruments. It can measure the ambient temperature between -25℃ to +85℃. The temperature is measured with an accuracy of ± 2.0℃ across the temperature range. The TMP102 is capable of reading temperatures to a resolution of 0.0625°C
The chip is a slave I2C device. A host processor will communicate with the TMP102 using the standard I2C protocol. The address of the chip is selectable on the breakout board. There are also two pullup resistors for the two I2C signals. The device is specified to operate over supply voltages from 1.4 to 3.6 V with the maximum quiescent current of 10 µA over the full operating range. The device is specified for operation over a temperature range of –40°C to 125°C.
The TMP102 device operates as a slave device only on the two-wire bus. Connections to the bus are made through the open-drain I/O lines, SDA and SCL. Because these signals are both open drain, the TMP102 can operate on both +3.3V and +5V Host MCUs. The board routes the +3.3V to power the TMP102 and to the pullup resistors for the open drain lines. The TMP102 device supports the transmission protocol for both fast (1 kHz to 400 kHz) and high-speed (1 kHz to 2.85 MHz) modes. All data bytes are transmitted MSB first.
This offer is for three TMP102 Temperature Sensor Breakout Boards. Each board is sealed in its own ESD protective bag along with a six pin 0.1 Inch steak-pin header. The PCB includes red soldermask with white silkscreen printing. Each PCB is 15mm x 15mm.
Enter your email address if you'd like to be notified when Three Pack of TMP102 Temp Sensor Breakout Board can be shipped to you:
4 Reviews | 321 Orders
$56.99
$6.99
$6.99
$27.99
$6.99
$24.99
