4ft USB 2.0 A-Male Micro-B Male 28/24AWG High-speed Shielded Data Charging Cable
Sold By Earth People TechnologyThis product is no longer available for sale.
$56.99
$13.99
$6.99
This USB Micro-B cable has been designed for DIY/Hobbyist. The power is distributed across two 24AWG wires to provide maximum current with limited voltage drop. The differential signals are separatel…
Read More…This USB Micro-B cable has been designed for DIY/Hobbyist. The power is distributed across two 24AWG wires to provide maximum current with limited voltage drop. The differential signals are separately shielded to deliver data at the max rate of 480MByte/second with no EM interference. The insulation is high quality industrial strength designed to resist the accidental solder iron encounter.
If you are performing a critical task like uploading your code to the Arduino Flash, do you want some cheap, low-quality cable that is prone to noise, interference and failure? Or do you want a high quality industrial strength cable designed for the DIY/Hobbyist? Yeah, we thought so. Buy this cable.
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
