$56.99
$13.99
$6.99
The VisiPort is a USB To Serial Adapter Module. It’s designed to be used in debugging microcontroller applications. It’s user signal inputs and outputs can be selected between +3.3 Volt and +5 Volt. …
Read More…The VisiPort is a USB To Serial Adapter Module. It’s designed to be used in debugging microcontroller applications. It’s user signal inputs and outputs can be selected between +3.3 Volt and +5 Volt. The VisiPort is based on the FTDI FT232RQ USB to Serial UART IC which handles all the USB signaling and protocols. The VisiPort supports RTS/CTS hardware handshaking and is USB powered. The module supports data transfer rates from 300 baud to 3 Mbaud
4 Reviews | 321 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
