Nixie clock PCB made entirely from TTL logic
Designed by HiRel in LithuaniaNo shipping info available.
What is it? Nixie clock PCB (output format is 24 hours HH:MM + blinking dot). In order to make your nixie clock work this board needs: 5V+-0,25V 0,5A power supply (it drains about 300mA) 32,768KHz …
Read More…Nixie clock PCB (output format is 24 hours HH:MM + blinking dot).
It was designed as a practical implementation of logic circuit design course. It turned out to be a very entertaining project which actually worked very nicely. Board contains one error which is solved by cutting one wire and adding a bodge wire.
This board is entirely TTL based and has no programmable options. In addition to that, it needs an external clock frequency which makes it a nice board to test your oscillator implementation on.
Enter your email address if you'd like to be notified when Nixie clock TTL board can be shipped to you:
$22.50
$48.88
$199.00
$300.00
