Soldering Station, 65W Solder Station Welding Iron with Smart Temperature Control (392°F-896°F), Extra 5pcs Soldering Tips
Designed by Electronic-Tools in United States of America
Designed for beiginer or professional use, the soldering iron station comes with a 65-watt heating element and built in smart transformer & PID temperature control that can detect its temperature eve…
Read More…Designed for beiginer or professional use, the soldering iron station comes with a 65-watt heating element and built in smart transformer & PID temperature control that can detect its temperature every 20ms for quick constant temperature return and then lock it. Ceramic heating core ( New Generation Heating Material) will perfectly improve temperature changes and efficiently solve fast aging issues.
Adjustable Temperature Range 392°F-896°F Meet different working temperature requirements, built-in smart transformer & PID temperature control will detect temperature every 20ms in real time for a quick temperature return and lock temperature!
Heating By Ceramic Heating Core Ceramic heating core, as a kind of new generation heating material, will perfectly improve temperature changes and efficiently solve fast aging issues.
Tips for Using: Applying solder where the joint will be made, not on the soldering iron. By adding it to the heated metal work surfaces instead of to the solder gun, the solder flows directly onto the location that it needs to harden.
Note:The temperature is being detected when led light is flashing
More documentation can be found in our website
Enter your email address if you'd like to be notified when Temperature Control Soldering Station can be shipped to you:
30-DAY MONEY-BACK GUARANTEE You can return & exchange your undamaged product within 30 days of purchase.
28-MONTH WARRANTY Each product (except accessories) purchased from Tilswall official store comes with a 28-month warranty from the date of the purchase. When you contact us, please include your order number, and we will provide technical support for you.
Shipped within 3-5 business days. Ship to US and CA only.
$84.67
