2x Flex-PCB for an OpenEPaperLink Mini-AP
Designed by {Electronics by Nic} in NetherlandsThis seller is taking a break until Jan. 1, 2025. Sign up below to get an email when they're back!
I'm out of flex-pcb's, and will not order new ones. As an alternative, take a look at the mini AP v3 This is the Flex-PCB for the OpenEPaperLink Mini AP. It's used to quickly assemble an AP without…
Read More…I'm out of flex-pcb's, and will not order new ones. As an alternative, take a look at the mini AP v3
This is the Flex-PCB for the OpenEPaperLink Mini AP. It's used to quickly assemble an AP without excessive soldering.
Each order will contain 2 (two) FlexPCB's; you can use it two build two AP's! Also, watch the volume discounts.
This version 2 adds a shielding ground plane for added stabiliy, an option (by solder blob) to power the tag from VCC or GPIO pins, and an option for an extra resistor/capacitor for extra stability of the EN-line.
You will need to add some items to make a working AP:
This is a very thin flex PCB; you'll need to be careful when soldering. Don't heat it too long or you will damage it!
Again: This is JUST a set of two Flex PCB's! Nothing else, except when you order segmented tags with it!
1 | $7.50 |
2-3 | $5.50 |
4+ | $4.00 |
