A beautifully designed clock featuring four upright circular TFT displays
Designed by {Electronics by Nic} in Netherlands
What is it? The QuadClock Orbix is a stylish clock with a minimalistic design, featuring four upright circular TFT displays mounted on a slim 7mm high base. It’s the first model in the upcoming QuadC…
Read More…The QuadClock Orbix is a stylish clock with a minimalistic design, featuring four upright circular TFT displays mounted on a slim 7mm high base. It’s the first model in the upcoming QuadClock series, where each display shows a single digit.
With 14 carefully chosen fonts, you can adjust the style to match your preference. The design focuses on clean, minimal aesthetics. There’s no cloud, no app, and WiFi is turned off by default (no need to worry about wireless signals near your bed), just a straightforward, reliable clock. Firmware updates are done through the website, by connecting a USB-C cable.
I have tested six different case colors so far. The basic black and iridium versions have smooth surfaces, while the wood and granite versions (Red Granite, Rosewood, Clay Brown, Yellow Ochre) are intentionally designed with a rougher texture for a more natural look. They all look great!
I wanted to create a product that I could design from the ground up. I first built a TFT clock a few years ago, and recently, I spent three months designing the QuadClock. It was an exciting process, creating the schematic, designing the universal PCB (the QuadClock PCB), developing the software, modeling the case, and putting together the documentation.
The software is fully open source, so you’re free to modify or enhance it as you see fit. If you have a contribution, feel free to submit a pull request on GitHub, and if approriate, I’ll merge your additions into the main branch.
While the bare displays give the clock a clean look, they aren't designed for rough handling. Be mindful around children and pets.
Due to the minimal case design, the speaker is quite small. While it’s not hi-fi or particularly loud, it likely produces enough sound to wake you up if you use it as an alarm clock.
3D Print Disclaimer: This item is 3D printed at home, and as such, minor variations in finish, fit, and material quality are to be expected.
While I strive to make the clock as polished and well-made as possible, it’s still a project handcrafted by a hobbyist, not a mass-produced product. Every detail has been carefully considered, and I’ve put a lot of passion into the design. I hope you’ll enjoy using it as much as I enjoyed creating it!
Enter your email address if you'd like to be notified when QuadClock Orbix can be shipped to you:
Many of the products are built on-demand. I do my best to ship as quickly as possible, but It might take a couple of days before I build your order, depending on work, weekends, travel, etc. Let me know if you're in a hurry!
Only if you're located outside the EU: Goods are dispatched from the Netherlands and will have a customs CN22 form attached. Some countries may charge import and/or local taxes when receiving goods from abroad. In some cases, the carrier may charge a fee to collect these taxes from you. These fees are not included in the item price or shipping charge, you are responsible for these fees and it is your responsibility to check with your countries customs and tax authorities before making a purchase.
1 | $99.00 |
2+ | $94.00 |
$12.80
$124.95
