Modify your car headlights to turn on after entering the tunnel and turn off upon exiting
Designed by ElektronikaBa in Bosnia and HerzegovinaNo shipping info available.
What is it? If you ever wanted to have your car headlights turned on after entering the tunnel and turned off upon exiting - this is a DIY project for you. The wiring is for Audi A3 8P but with sligh…
Read More…If you ever wanted to have your car headlights turned on after entering the tunnel and turned off upon exiting - this is a DIY project for you. The wiring is for Audi A3 8P but with slight modifications it could be connected to other vehicles as well.
If you plug in the original car harness (cabling) the other way around, you will burn your light switch! This switch goes simply between the original car harness and the switch. When you disconnect the car harness from the light switch, make sure you plug it in the device (the headlight switch mod that you purchased) in the correct order - the way it originally was.
I had shipping problems when sending to:
Enter your email address if you'd like to be notified when Audi A3 8P automatic headlight mod can be shipped to you:
Tuzla, Federation of Bosnia and Herzegovina, Bosnia and Herzegovina
Ships from Bosnia and Herzegovina.
