USB front panel for the Joulescope JS220
Designed by Empirical.EE in Australia
Joulescope JS220 uUSB Front Panel The uUSB FP is a versatile panel for the Joulescope JS220 power analyser that enables power measurement of any USB device. Key Features Multiple USB connector types…
Read More…The uUSB FP is a versatile panel for the Joulescope JS220 power analyser that enables power measurement of any USB device.
Think of the USB Front Panel (FP) like a USB extension cable - it simply passes through power and data between devices. Just as an extension cable's capabilities depend on what you plug into it, the USB FP's power handling is determined by:
Important: While the USB FP can pass through various USB power technologies (including USB Power Delivery), the Joulescope itself has a maximum current rating of 3A. Exceeding this limit may permanently damage the device. Exercise caution when using USB-C connections (see note below).
⚠️ USB Type-C Connection. Due to USB Type-C specification limitations:
The panel routes the data lines through all the connectors to provide maximum connectivity flexibility. This is inherently going to impact signal integrity.
In order to measure the impact, I connected a USB 3 capable drive with a USB 2.0 extension cable to make USB the bottleneck, not the drive. This was the baseline reading.
For the uUSB FP reading, the USB drive was connected to the panel, then the panel was connected to the laptop (host) with the USB-B port.
Using the USB test script, the following graphs were produced. The script ran 30 tests of 512MB transfers.
The average read speed was only 0.4 MB/s slower than baseline, but with more consistent speeds. This is likely noise from the tests.
The average write speed is very similar to the baseline, however there is greater fluctuation.
The read and write speeds achieved without the uUSB FP, while lower than the USB 2.0 HS theoretical maximum of 60MB/s, are typical data rates in practice. Introducing the uUSB FP shows only a small reduction in maximum speed, although there appears to be more fluctuation. Given the signal integrity reduction inherent in a passive pass-through device, this is not unexpected. The overall speed achieved is a function of the protocol, the cables, the uUSB FP, the host computer and the USB drive itself, so individual results may vary.
The white USB cable with the USB drive attached is the baseline test, and the uUSB test would have the USB drive plugged into the Joulescope.
The script used for testing can be found here. Note the script is built for Linux and it might run Mac OS, but changes will have to be made in order to use it on Windows.
The schematic is located on the GitHub repository.
Enter your email address if you'd like to be notified when uUSB Front Panel can be shipped to you:
