Two-Wire self-regulating 'SugarCube' Micro LED Driver
Designed by EZ-Rays LED Drivers in United States of America
Power LEDs with this efficient, small size 'SugarCube' LED driver. (Case Version 2) Designed for 1.5 - 3 Volt operation. Use this tiny LED driver to illuminate typical white LEDs two-wired in series,…
Read More…Power LEDs with this efficient, small size 'SugarCube' LED driver. (Case Version 2)
Designed for 1.5 - 3 Volt operation. Use this tiny LED driver to illuminate typical white LEDs two-wired in series, parallel configurations! This easy-to-use LED driver will allow simple lighting on artwork, scale models, crafts and more! This small footprint converter can be built directly into your work! Easy common ground configuration makes connecting a breeze.
The LDEC15MX can be used with typical LEDs with forward voltages of 3.5V to 4.1V @ 20mA forward current ratings. Illuminate a string of LEDs wired in series (up to 10) with no noticeable decrease in light emission or parallel (up to 15).
The driver is self-regulating, so if you are using a series of 3 or 10 LEDs, the output voltage will adjust accordingly up to the LED and driver maximums. In parallel mode the current will self-regulate to the ratings of the LEDs and driver itself, using more current for 15 LEDs wired in parallel or less if using a smaller number of LEDs. No resistors needed.
Includes: - Detailed Instructions and (1)LEDC15MX Pulse switching DC/DC converter(case color may vary)
TW Version | LEDC15MX (Series/Parallel) |
Size | 10mm x 10mm x 9mm |
Weight | 4g |
Input | 1.5 - 3V DC |
Output | ~4 - 30V @ 50-90mA Pulses |
LED Specs | Typical: If=20mA, Vf=3.4 - 4.1V |
Enter your email address if you'd like to be notified when Micro LED Pulse Driver (SugarCube) can be shipped to you:
$24.99
$79.00
