Turn your Raspberry Pi Pico into a debug probe
Designed by Fabien Chouteau in FranceNo shipping info available.
The Picoprobe-pcb-kit is now exclusively available from Pimoroni: https://shop.pimoroni.com/products/picoprobe-pcb-kit If like me you love the Raspberry Pi Pico/RP2040, but your are not satisfied …
Read More…The Picoprobe-pcb-kit is now exclusively available from Pimoroni: https://shop.pimoroni.com/products/picoprobe-pcb-kit
If like me you love the Raspberry Pi Pico/RP2040, but your are not satisfied with the available hardware debugging solution, this kit is for you ^^
This PCB is designed to turn a Pico into a nice debug probe using the PicoProbe software.
The kit provides everything you need to turn a Raspberry Pi Pico into a debug probe (Raspberry Pi Pico not included):
There are two ways to mount a Raspberry Pi Pico on the Picoprobe-PCB. You can either solder it directly for a slim/compact result (right), or use header to be able to re-use the Pico on other projects (left).
Either get the picoprobe .uf2
binary from our release here or compile it yourself from sources here.
Hold the BOOTSEL button on the Pico, then connect to your computer using a micro USB cable.
Drag and drop the UF2 file on to the RPI-RP2 drive.
You should be good to go.
$ sudo apt install automake autoconf build-essential texinfo libtool libftdi-dev libusb-1.0-0-dev
$ git clone https://github.com/raspberrypi/openocd.git --branch picoprobe --depth=1 --no-single-branch
$ cd openocd
$ ./bootstrap
$ ./configure --enable-picoprobe
$ make -j4
$ ./src/openocd -s tcl -f interface/picoprobe.cfg -f target/rp2040.cfg
Now that openocd is connected, you can start debugging with GDB for instance.
$ arm-eabi-none-gdb
(gdb) target extended-remote :3333
Kyle (@AandKP) designed a case for the PicoProbe PCB. You can find it on Thingiverse.
Enter your email address if you'd like to be notified when PicoProbe PCB kit can be shipped to you:
