A dirt-cheap hardware to carry out voltage glitching attacks against microcontrollers with a Raspberry Pi Pico (partially populated)
Note: this is the partially populated version of the Pico Glitcher, meaning that the SMD components are already soldered on. You have to separately buy and solder the rest of the following components…
Read More…Note: this is the partially populated version of the Pico Glitcher, meaning that the SMD components are already soldered on. You have to separately buy and solder the rest of the following components:
Enter your email address if you'd like to be notified when PicoGlitcher v1.1 (partially populated) can be shipped to you:
$230.00
$16.99
$14.95
$11.95
