A device to carry out voltage glitching attacks against microcontrollers with a Raspberry Pi Pico (partially populated)
Designed by Faulty Hardware in GermanyNo shipping info available.
Note: this is the partially populated version of the Pico Glitcher v2, meaning that the SMD components and the Raspberry Pi Pico are already soldered on. You have to separately buy and solder the res…
Read More…Note: this is the partially populated version of the Pico Glitcher v2, meaning that the SMD components and the Raspberry Pi Pico are already soldered on. You have to separately buy and solder the rest of the following components:
Compared to hardware revision 1, several new features have been added in revision 2. However, the basic usage is the same and the scripts for version 1 will also work for version 2. The hardware is based on the Raspberry Pi Pico, two high-power MOSFETs for crowbar glitch generation, and two level shifters to ensure compatibility over a wide voltage range. A newly designed input stage (EXT1 and EXT2) can be used to filter out noise and other disturbances via adjustable Schmitt Triggers. The multiplexing output can be used to quickly switch between up to four different voltage levels and to supply the target board with power.
Enter your email address if you'd like to be notified when PicoGlitcher v2.1 (partially populated) can be shipped to you:
