STM8 Target Board specifically made to glitch with the Pico Glitcher
Note: Only choose the diy kit, if you have a way to program the STM8s microcontroller. Since I cannot program it if the board is not assembled, you have to do it yourself. To program the target board…
Read More…Note: Only choose the diy kit, if you have a way to program the STM8s microcontroller. Since I cannot program it if the board is not assembled, you have to do it yourself. To program the target board, follow this guide: Programming the STM8s target board
The STM8 target board has been specifically designed for attacking with the Pico Glitcher. This board will teach you how to use the Pico Glitcher and how to attack other microcontrollers using the crowbar or multiplexing method. The board also has a USB to UART adapter, which you can use either to communicate with the STM8 MCU in bootloader mode, or to interface with other microcontrollers.
Attacking this board is easy, see the documentation for more information on how to set up the Pico Glitcher.
Only the STM8 target board with pin headers and the SMA connector is included. The Pico Glitcher can be purchased separately here.
Enter your email address if you'd like to be notified when STM8 Target Board can be shipped to you:
