Full colour LED cube display. Many built in patterns. Responds to audio. Ability to link multiple devices together.
Designed by Feral Makes in United KingdomNo shipping info available.
A 3-dimensional array of RGB LEDs, commonly referred to as an ‘LED cube’. This unique device features 125 RGB LEDs arranged in to a 5x5x5 array, which puts on a mesmerising light show with many diffe…
Read More…A 3-dimensional array of RGB LEDs, commonly referred to as an ‘LED cube’. This unique device features 125 RGB LEDs arranged in to a 5x5x5 array, which puts on a mesmerising light show with many different patterns to choose from.
The LED cube also features a built-in microphone and includes patterns which respond to sound, either based on volume or frequency (spectrum analyser functionality).
Revision 2 of the LED cube comes with many improvements over the previous version, including additional patterns and refinement of old ones. The new defining feature is the ability to link up to 5 devices together to achieve a larger display, up to an array size of 25x5x5 or 625 LEDs!
Features:
-14 static patterns plus 6 audio based ones.
-Automatic gain control of the microphone allows use over a wide range of sound levels.
-Connect up to 5 devices together using the supplied link adapter; additional devices are detected automatically and pattern generation is adjusted accordingly, no configuration required.
-Procedurally generated patterns produce a different result through each iteration, using ambient noise in the random number generator algorithm.
-User configurable brightness and pattern settings, automatically stored to and retrieved from memory upon power up.
-USB C powered for convenience, can be powered from most USB ports (1A or greater capability recommended, multiple devices each require their own power supply).
Items included:
1 x 5x5x5 RGB LED cube
1 x 2m USB C cable
1 x link adapter
1 x manual
Technical specifications:
-Peak current draw (maximum brightness): 1000mA
-Average current draw (maximum brightness, automatic mode enabled): 500mA
-Operating voltage: 5V +/- 0.5V
-Input protection: resettable PTC fuse (1A)
Enter your email address if you'd like to be notified when 5x5x5 RGB LED cube Version 2.0 can be shipped to you:
1 | $85.00 |
2 | $80.00 |
3+ | $75.00 |
