Adaptors for using surface mount components with breadboards (sizes 0201 to 2512).
Designed by Feral Makes in United KingdomNo shipping info available.
Adaptor PCBs for surface mount components such as resistors, capacitors, inductors, LEDs and more for use with with 2.54mm pitch prototyping platforms such as breadboards, stripboard and veroboard. E…
Read More…Adaptor PCBs for surface mount components such as resistors, capacitors, inductors, LEDs and more for use with with 2.54mm pitch prototyping platforms such as breadboards, stripboard and veroboard.
Each adaptor has footprints for 4 sets of 2 components in series with the centre terminal broken out to a separate pin if required (useful for voltage dividers and filters), the centre tap can also be used if a series configuration is not needed. Traces and footprint sizes are clearly marked with silkscreen for ease of use.
Typical applications:
-RC & LC filters
-Resistive voltage dividers
-LED & resistor series combinations (see example image)
-Characterisation of surface mount components
Each adaptor is double sided and accommodates two different component sizes which are:
-0201 & 0402
-0603 & 0805
-1206 & 1210
-2010 & 2512
Price is for one pack which includes 5 of each size (20 in total) and 6 strips of 40 male headers.
Enter your email address if you'd like to be notified when SMD Resistor / Capacitor / LED to DIP Adaptors can be shipped to you:
1 | $15.00 |
2+ | $12.50 |
